Auto-add pages option
I want to delete other websites from the drop down. I did an online search and it said to delete the auto-add pages option from the menu but I can’t find the auto-add pages option. I’m using the Sitely app for Mac, version 7.0.3. Please help!!
Welcome onboard @Mimi :waving_hand:
I’m not sure what you are getting at here?
Are you meaning the File / Open Recent ? If you are then at the bottom of that dropdown you can Clear Menu. This will remove all your website in the dropdown list. But I should add this does not delete any website files on your iMac.
Yes, exactly BUT I don’t want to delete all of them. And I know it doesn’t delete the website files. If I delete the files, do I assume that it will also delete on the dropdown? That kind of makes sense.
Hi @Mimi, the auto-add pages is the menu element that you add to pages.
You in fact want the File → Open Recent menu. That list of recent files is the same in several parts of Sitely:
  • the File → Open Recent menu
  • the Welcome window, where you see the list of recent files
  • the context menu of the Sitely dock icon
That list of files is managed by the Finder, and all apps (that follow Apple’s document architecture) have a File → Open Recent. At the bottom of that list there’s a Clear Menu, also automatically handled by the Finder. Selecting that will remove the list of recent files from all three locations. It does not delete the original files. The “Clear Menu” kind of points to that, but I’m guessing better safe than sorry.
Deleting a file isn’t required, and it’s a fairly blunt way to tidy that list. In practice macOS rebuilds Open Recent from its record of documents, so once a file is deleted (or moved/renamed) the entry usually stops resolving and drops off — but it can linger as a stale item until you click it or the system next cleans house. There’s no built-in way to remove a single entry; Clear Menu is the only supported route. If you want to keep the file but hide it from the list, moving it to another folder achieves that without deleting anything.
