Blog Index problem
Hi helpful Sitely users
I have an issue with my Blog that is confounding me. Everything is fine except that the first two pages, which have quite long content, show in the Blog Index with a huge white space below the text that I cannot seem to eliminate. You can see the problem at BLOG — Index if you scroll down to near the end of the page.
Can someone suggest how I might fix this please?
It’s hard to make it out without seeing your Sitely file, but…
Have you got your text box really long on the second last blog post and somewhat long on the last blog post?
Thank you for replying, FlaminFig. The text boxes are long because those posts have more content than others, but the text box is no longer than it needs to be for the content. However, after seeing your reply and checking again, I found I was able to reduce the size of the text box on the index page without affecting the content on the blog page. For some reason, I couldn’t do that before. I tried, but I wasn’t seeing any handles on the text box on when editing the index entry. Weird… but all good now. Thanks again.
