Dark menus look in Sitely
Hi there,
Sometimes I see screenshots from several users using Sitely (Sparkle) with grey/dark menus. Where do I find the option for changing the color of the app menus to grey/dark?
Thank you in advance.
Regards
Kaffeebart
If you enable dark mode in your Mac’s System preferences, Sitely will also switch to dark mode.
Oh OK, too bad. I’m not a fan of dark mode in the whole system. It would only be helpful in Sitely directly, as the contrasts help you to find your way around better.
So there is probably no way to change the user interface? Maybe that would be something for the developers’ to-do list :wink:
Thank you for the quick answer.
If it was possible I would also love the ability to change the light/dark setting within Sitely instead doing it through the System Preferences! :slight_smile: .
I’m not a fan of dark mode either, I just showed you where you can adjust it.
I would prefer this setting to be specific to applications.
