I am creating a customer review page and would like to use a star rating similar to the following. Any ideas on how to do it?
This isn’t something that Sitely can do natively, but it’s relatively simple to create and embed a widget into your pages that will accept a star rating from users and save it to a csv file where it calculates an average rating and displays in your page.
If you can tell me what hosting/server or where your site is hosted, I can work out whether PHP/CSV is possible and give you the complete copy-and-paste star-rating system - PHP file + Sitely Code snippet
You can see it working on this demo page: Demonstration of Star-Rating Widget for Sitely
Later, changing its location and/or adjusting its size etc. can be done with Sitely pop-ups, although it requires some effort. I don’t know if it can connect to any database?
I made an example, you can see it at the link below.
A nice implementation
Hi Stephie,
Sorry for the delayed response; I’ve been celebrating another trip around the sun. I’m using Accu23 and have full PHP and file access.
Thsnk you for your assistance!
This how the ratings Widget works - download link is at the foot of this message.
How the Rating System Works
Once your website is published, visitors can select a rating from one to five stars. When a visitor submits a rating:
The rating is sent to the PHP script on your server.
The rating is saved to a CSV file.
The system calculates the average rating for that particular item or page.
The updated average is sent back to the widget.
The widget displays the average rating numerically and graphically using
fully or partially filled stars.
The CSV file is created automatically when the first rating is submitted, so there is no need to create or configure it manually, and there is no need for a database..
Preventing Multiple Ratings
The system includes measures designed to discourage multiple ratings of the same item by the same visitor.
It uses a combination of browser-based storage and an anonymous server- side visitor identifier to help prevent duplicate ratings.
However, like most simple website-based rating systems, this is not completely foolproof. A visitor may potentially submit another rating by, for example, using a different browser or device.
The system is therefore intended as a straightforward and practical rating solution for general website use, rather than a high-security voting system.
Here is the download link for the Sitely Star Rating Package:
Full instructions for installation are included in the package - Just save the downloaded zip file to your desktop and decompress it. Follow the instructions in the PDF file.
