Is it possible to attach more than 1 file in a form?
Hi Community,
I have created a form at the end of which you can attach/upload a file. Works pretty good so far. But: I wonder if you can also add a second file somehow? Is there such a feature? Or would I have to create a second “upload box” underneath, then a third, a fourth, and so on?
Regards
Kaffeebart
You just about got it @Kaffeebart
Your second way of understanding it (stacking “upload file” containers) will work just fine.
Thank you.
But isn’t there a more “elegant” solution? I can’t know in advance how many files a customer wants to upload. :thinking: :thinking:
No, not at this stage…
