Hi Duncan
Sometimes Sparkle does not save in a first try using Command+S or by using a “save” from file menu. Only a second attempt is successful.
I’m using Sparkle 2.8.9 under MacOSX Catalina
Best Regards.
Hi Duncan
Best Regards.
I’m not really sure how you determine which save is effective?
The first try does not give any echo. A second save, at least in my project, takes 29 seconds until the beach ball disappears. I assume that, due to this behavior, only the second one is effective.
Ok. They’re actually both effective. There’s a queue though, so while one is saving you can’t also save a second time, so the second time you save is just waiting on the first to end.
Great. Thanks Duncan.
