Why when I make the publishing settings I can’t see the path and root where my site folder is. Sparkle goes from first screen to next (save)
Should I see this screen?
No, what that means is Sitely has auto-detected your web host folder configuration and you are done. You can save and publish.
Yes I understand Duncan, but all files and folders are not in the right folder named ctibmobile.ca. See the screen capture
What that means is that your web host has configured the two domains to share the same folder. You need to ask them to separate the folders.
Resolved. The problem was 400 cm in front of the screen.
