Hello,
I created a horizontal menu bar consisting of 5 sections. Each section has 3-5 submenu items.
I have set the Menu font to be bold. I then clicked the Custom Style checkbox to make the text in the submenus not bold.
However, Section 1 submenu item 1 remains bold while submenu items 2 and 3 have successfully changed and are no longer bold. I have tried redoing the custom style, bolding/unbolding, quitting and restarting Sparkle but cannot figure out a solution.
Thank you for your help…
Might be a bug! Hard to say without looking at the project file. Can you send it over to feedback@sparkleapp.com? Thanks!
Hi @duncan thank you for your reply.
I ended up doing a quick test repeating the steps that I did on a new project and I was unable to recreate my issue. So I really do not know what I did or what happened in my main project… however, I ended up deciding on going ahead with a simple workaround:
- Delete the first submenu item that would not change from bold to regular font;
- Adding a new submenu item (it appeared as regular font), renaming, relinking it and reordering it as submenu item No. 1.
This worked…
