I purchased a template from themeforest. Can Sparkle use this template?
Hi @sd85812 and welcome onboard!
The only way Sparkle can use your template from Themeforest is that you import the template demo website into Sparkle, by going Create New Website / Import Your Website.
Sparkle will import the desktop version which you might have to do minor adjustments too, but after that you will need to play with the Sparkle Devices… like tablet and definitely mobile which you will need to adjust to accomodate mobile.
Sparkle itself offers templates on creating a new website, but there are also a few of us that do Sparkle templates like myself - https://flaminfig.com
I hope that helps!
