How can I change the form variable of all the text fields so the email that arrives is readable and makes sense? I am working on a form but at the text input section this field is grey and can not be changed.
(see picture below)
it results in emails with
username:
username:
username:
… instead of actually address, city, occupation and so on. can somebody please tell me how to change this?? i am desperate
Hi @Dooria79
It looks like you’ve used an input field that is specific to the “Login Form” element, and not a standard “Text Input” element designed for creating contact forms.
The “Login Form” element is specifically for allowing your users to log in to access a reserved area on your site. It is not a pre-designed contact form example.
To create a contact form, you need to use the standard “Text Input” element. You can add it to your page by selecting it from Sitely’s “Add” menu.
OMG!!! THANK YOU THANK YOU THANK YOU!!! I did NOT notice that!
