I get this warning from time to time.
Am I missing something?
In that phase Sparkle writes a random file to the folder and looks for it on the web side. If that file is not found it generally means the folder is incorrect. What sometimes breaks this mechanism is a server side cache, but Sparkle has no way of knowing if there’s a cache, or what the difference between a cached folder and an incorrect one is.
Is there anything I can do?
I think your web host might have a server side cache. It’s not really helpful, can you check and disable it?
I think I can’t… (:
I will wait 1-2 days…
Thanks…
