A couple of potential bugs?
Hi folks, new Sitely guy here! Am loving it so far, esp. the creative possibilities.
I have noticed a couple issues:
  1. When adding images with transparent backgrounds to wide or layout blocks, the transparent background doesn’t show as it should in Sitely itself but when I preview there or in browser the background is no longer transparent. If I insert it as a graphic it works properly, just not within blocks?
  2. The blog index page keeps shifting around so it’s hard to pin down. I tried locking it but it still moves around when new posts are added sometimes, even when they are duplicates. This is a bigger issue when the blog index goes to the second page and there the index is shifted over to the left and throws the layout off but on the first index page it is fine. Whenever I adjust the index layout on the second page it moves the index over on the first page too (as it probably should) and then that page gets thrown off so it’s confusing.
Thanks for advice and suggestions.
Ray
Hi @AlongtheRay, best if you send a test project showing the issue to feedback@sitely.app so we can produce and look into it. Thanks.
Sent! Thank you.
Ray
