This website was created to inform our community about our organization in Basel and our activities.
Welcome onboard @Basilea ![]()
Well done for your first Sitely website! ![]()
Can I please suggest you check the following…
- On your news page your dropdown navigation plays up if you are partway down the page which is caused because your nav bar isn’t set to the highest level in the Layers panel.
- On mobile you seem to have sideways movement which is placing your content off center.
You should create the red line in the footer with a box instead of the letter I.
Otherwise, such problems may occur in translation. ![]()
Hello FlaminFig,
thank you for your feedback.
I have since been able to fix both errors.
Wishing you a happy new year!
Basilea
Hello selsuk,
Thank you for your feedback.
I did indeed make the red bar with an I, now converted into a box.
Basilea
