Any advice about adding a Tumblr feed to your website? It’s the only feature I have not found to be a huge improvement from Muse.
@Valordesigns, Welcome onboard!
With Sparkle you can add a lot by using the Embed block. In the case of adding Tumblr use this website as a guide - How To Embed Tumblr Feeds On Website - Tagembed and you’ll see that by using the code generated and pasting that in a Sparkle Embed block that you can also add a Tumblr feed to your Sparkle website…
