I updated my Sitely version from 6.06 to 6.1, and since then my Lottie animation has not been functioning.
After resetting Sitely on my iMac to version 6.06 (thanks to TimeMachine), everything is working as it should again.
The following error message appeared in Firefox Inspector:
falling back to ArrayBuffer instantiation 55f7e726-4588-4447-b5a6-c034959171c2:134:55
XHRGET
https://www.malerbetrieb-xxxxx.de/images/c/kombinierte_Drahtmodelle.json
CORS Missing Allow Origin
Failed to load animation data from URL: https:/www.malerbetrieb-xxxxx.de/images/c/kombinierte_Drahtmodelle.json.
TypeError: NetworkError when attempting to fetch resource.
As you can see, the last address is only implemented with a single ‘/’ after the https:, which is probably the error.
I hope you can identify and fix the error.
Best regards, Martin
