Dear community,
As you may know, legislation in Germany regarding accessibility has changed. I’m therefore looking for a way to add alt text to images inside a box – or alternatively, to display an image at full page width.
Best regards,
Steffi
Dear community,
Best regards,
Steffi
@Steffi, if you give your image a “description” that is the same as the html “alt”. You can do this whether the image is alone standing or in a Box element.
To display an image at full width you first need to right click it and turn into a Box. Once done if you now go to the column on the right under Arrange you will be able to “Full page width” it.
Hi Flaming Fig
This is what I usually do, but Seobility and all other tools want an atlernative description.
Have you tried Google PageSpeed to see if your get the same error?
It is somewhat strange SEOability is saying it isn’t satisfied the Sitely image Description is not an “alt”. If you check out the code behind your Sitely website in your browser the Description is definitely coming up as a html “alt” tag.
Thank you, I’ll try.
