Aria-labels for accessibility
Hi, is there a way to create aria-labels other than custom code in Sitely, for accessibility, or is this something in the works? Love this product so much. thanks!
Hello @kcapraro, we made big push on accessibility in v6. Are you using it? I assume you had some validation point out missing aria-labels? In general we’d like to have those set automatically wherever possible. Perhaps there’s something we missed and we can add.
Hi Duncan, Oh v6 totally helped thank you — awesome! I was using links to go to anchors on the page and the feedback I’m getting is the navigation landmarks are not defined, it’d be cool if that was automatically defined in Sitely. Thanks again for making this tool.
Hi again, looks like I needed to add aria-labels to a couple of open pop-up buttons. Hope that helps.
Yes except it’s a bit too vague. Perhaps you can email us the details (link to the page, project file, screenshot of the error message from the validation tool, etc) so we can look into this.
