Hi there, I am working on a Nails Salon website and I wanted to include a booking section for customers.
I came across to SimplyBook.me which provides an iFrame embeded widget that can be implemented on a webpage.
Is anyone so kind to explain to me how/where should I insert the iFrame widget?
Thanks so much guys!
Iggy
Hi @Nemo…
Just thought to check first. Do you know about the booking services Sitely has integrated when you look under Monetization? They are third-party but works nicely with Sitely.
When wanting to place an iframe you need to first place an Embed widget down on your canvas. You then click on the Embed widget which will highlight a number of things you can do with it on the right hand panel. You want to pace your iframe content into the container marked Embedded Content. If you know your content will expand on the page then click on Content Expands Vertically.
You will also need to decide how you’d like to implement Privacy. If dealing with EU clients you’d probably leave ticked Activate After Consent.
Hi Handrik! Thanks so much. I did try the embed widget and it works fine!
