Button behaviour
Can I have a button that is independent of any text or objects, just always shows in the same place on screen?
When the Button is selected, check under Arrange/Visibility. Is this the functionality you are wanting?
I could suggest @andrex991 to place your Button in a Popup, with the setting Fixed in Window. So wherever you position your button that is where it will remain regardless of what is moving underneath it when you Preview it in the browser.
Don’t forget to set the Popup to Open Automatically and bring the Delay down to 0 seconds.
