Button showing <br>
Hello,
I have created a contact form for my website sendmeyourcv.com but on the submit button on the live site there is a
after the SEND MESSAGE, this does not appear in sparkle itself, but does appear in preview. Does anyone know how to remove it? I have included a screen shot of the button in Sitely and a screen shot of the live site
I can always do a screen shot of the settings if that would help?
Thank you in advance
Simon
@Sicherry, is your contact form entirely created in Sitely and not a third-party add on?
Yes completely made in Sitely
I have just solved it, I knew the br meant Break from the little knowledge I have of coding, so went to check the button label in the right hand side of Sitely and did notice I had a line break after the label, I removed the line break and I think this has fixed the problem. User error.
Thank you Hendrick for taking the time.
He he he Simon… That was the next things I was going to suggest.
Well done in sorting it out! :slight_smile: :clap:
Hi @Sicherry, yes that’s the correct workaround. The bug itself is a regression in 5.6.3 due to the many changes we’re doing on buttons to account for all the features buttons have and compatibility with bugs and glitches in different browsers with mouse hover, transparency, animation, etc. So that particular issue is fixed in 5.6.4.
