So Sitely 7. You know it’s going to be a free license upgrade for everybody that has a Sitely 6 license (hopefully all of you!), and you know some of the main features.
The new features, and the under the hood changes, would benefit from more testing. If you’re using Sitely frequently, are keen on using software that can misbehave (incorrect behavior, occasional crashes), we’d love you to help out.
Still supports macOS 10.14 or later, so still supports Intel. Apple is removing Intel support in macOS 27, but Sitely will still support older OS versions and Intel.
