I have a anim. gif of a tape recorder (rotating the reels) and a png of the same one.
I would like to place the png on top of or near the play button of the audio file. And when I press PLAY the animated gif should be visible. On STOP the png should be on top (stopping the animation).
I know, it’s just a gimmick, but it would be nice, if I could do it with Sparkle.
Every suggestion is welcome.
I believe you can get this effect using a button and popup. On the button, you can place the png file and place the gif on a popup. You set the popup to close when the mouse exits the popup. You need to place both items exactly on top of each other.
Thanks Nathan. I tried that before and tried it again. The problem is that the gif in the popup isn’t animated, at least not in preview. I didn’t try to upload it yet, as I don’t want to mess with my active website. I saved it to disk for viewing, but the give is not moving neither.
Is this what you have in mind?
Sort of (ideally it would be activated, when the audio file is playing). But thanks a lot!
How did you do it? I don’t see any .gif just jpgs in the button part and nothing (no image) in the popup part.
Edit: Sorry, I overlooked the image in the popup. Now I see the gif. I’ll try with my images and report back.
Thanks again.
EDIT 2: By replacing the images in your Sparkle file IT WORKS! I don’t know exactly why, but thank you VERY MUCH for your time and effort and Happy New Year!
Happy New Year for you too.
