Actually it’s a layout block, with a header, and a layout grid below it. I don’t think I can add the header to the grid block, so I’d like the button to toggle BOTH of them. Is this possible?
Hi
No, that’s not possible at the moment. I recommend using regular layout blocks and grouping your elements. This will work in a similar way, and you’ll be able to include the header without any issues.
