This is the most maddening part of Sparkle I have encountered - for some reason, a I cannot adjust the size of a layout block. When I click on the lower diamond to raise or lower, I can make the block bigger, but can’t make it smaller, and there’s a huge chunk of blank space between the text box in the block and the bottom of the block. I change the size the the style panel, but it goes back to the size of 3017. AAAAAA!!!
You most likely have an element within the Layout Block that is preventing it to be made shorter in height. Do your have a background Box or Wide-Box?
Once you find the element that is maxed out to the edges of your Layout Block and reduce it in hight you’ll be able to reduce the height of your Layout Block.
Wow, that’s crazy - it was an element that I had checked to not appear on that page. Thanks for helping me figure it out, it was driving me insane!
