I’ve noticed that the children of top level groups appear without indentation, and, as a result, the last child element is visually confused with an independent top level element.
Meanwhile, the children of nested groups are indented, clarifying the hierarchical relationship.
Is there anyway to eliminate the confusion between the children of top level groups and the independent top level elements that follow in the Layers panel? Either through indentation, or though some horizontal rule divider?
