I used to create clickable image maps way back when with GoLive 4. The image might contain 3 or 4 areas which when linked to another page, become hot spots when you mouse over them.
Is that a feature in Sparkle ? If so, what is it called ? Thanks, C
I use a transparent Button element, with a border initially so I can see it. Many ways to tweak it.
i’ve done this combining buttons + popups, specifically using hover configurations on the buttons to open popups
Finally got back to this - your idea worked very well. Thanks. You can see it (or not see it) at https://www.anvilgraphics.com/
