I’m using about 10 pop-ups in this new site. All ‘Normal’ and all with the typical ‘Close’ Button (black dot with an X in it). What surprises me is that some of those buttons close the pop-ups like they should and some just don’t. I copy/pasted ‘good’ close buttons on other popups but they still refuse to close.
I read the documentation and discussions again and tried a lot, but I don’t get it.
I have a workaround: I still use the close button but instead of close on click I selected (on click) to go to… the same page. That works every time, but is not how it should be.
Thanks, Duncan. I had just changed the setting of the close buttons, so after your request I changed some of them back to ‘close this pop-up’. Surprise: now they work…
Feature Request:
Make a popup auto-close after say, 10 seconds.
Is this possible?
A client of mine wants this. Told him good idea but not currently possible.
Anyone out there have a suggestion how to make this happen?
Thanks!
Dave
You can do that indirectly by adding a countdown smart field, that closes the popup as its end action. You can make the text invisible if you don’t want the counter to be seen.
