I have the developer tools, and have been working on a site with this access. But now, when I create a new site, the Code Integration field at the bottom of theArrange panel does not appear. I can’t remember, since I got the developer tools quite some time ago - is there something I’m supposed to do per site to make that appear? Or is aomething broken? I’m running the most current Sitely version as of 3/27/25. Thanks for any insights!
Hi @khincker ![]()
To make the element ID customization field appear in the “Arrange” panel, you first need to enable the option in your site settings. Go to the “Miscellaneous” section, then activate the option “Allow HTML element ID customization.”
But this setting is available to all users and is not part of the features exclusive to those with the “Developer Tools” option.
