Hi all. I’ve been duplicating a website made with a PC program and I need an exact color from that website. I need input on what I need numerically, or RGB. I did try a #number but it didn’t translate in the OS Sparkle color wheel. The color is so subtle I can’t eyeball the color. Any ideas.
My Thanks
-Bill
Have you used the dropper in the colour well to select the colour at all?
I just purchased this yesterday from the Mac app store it’s called Color Ninja, I thought that it might be useful…
Best,
Scott
Thanks Scott. The color I need is the bright lime color on the menu and scattered throughout this site. Www.northeastspca.org. I’ll try numerically from the PC site and see if it translates.
-Bill
Just checking your site’s lime green colour @Woodrow - rgb(195, 236, 9) which translates to #B9EC09
If you place either one in the “colour well”, see screenshot, towards the bottom right labeled “RGB” or “#:” you will get your colour in Sparkle…
You saved me again @FlaminFig. I don’t know how you did it but many, many thanks.
-Bill
Well, his name IS “Greenskin”, after all
Dave
