Trying out the new magic box function after creating a API key in Claude.
The API key create was pretty straight forward but after entering the key in the destination space and added a prompt in the prompt box the enclosed message showed. What could be the issue? Claude gives me the answer that the API key gives me access to whichever model I am using.
“Magic Box Generation Failed”
HTTP 404
model: opus-4.7
OK
