When I use the quote feature it automatically indents 40 px left and right. That works great on the desktop view, but for smartphone that’s too much of an indent. 20 px works much better. Is there any way to make 20 px the default indent for smartphone while leaving 40 px the default for desktop?
Defaults values are baked into Sitely so as to give users the ability to start creating web pages right out of the box with pre-set values. However, all defaults can be overridden on a project by project basis. The Quote style setting can also be overridden, and it can be overridden for each device variant. For example:
The desktop version of the page may set left and right indents to 40px. However, if you switch to the mobile variant you can set these margins to 20px. Your changes won’t affect the desktop variant or any of the other device variants you may add.
I know that I can reset each quote indent from 40 to 20 manually, but is there a way to set the default globally so I don’t have to do that? It’s ok if it’s on a per-project basis.
The defaults are baked into the app, so, as far as I’m aware, they cannot be changed.
Thanks. I found a way to change the smartphone quote padding through CSS. That might create problems with the position of the page bottom, though. I’m experimenting with it now.
As expected, using CSS to shrink the width of quote blocks wreaked havoc with the page bottom and footer placement. So, I spent several days working with ChatGPT and now I have a script that places the page bottom and footer automatically. In Sitely’s editor it doesn’t matter where I leave the bottom of the text or where I leave the page bottom. The script automatically puts them where they should be.
