I run Sparkle, I choose a model, it does not open
I go to the site> https://sparkleapp.com/designs/three-stars-by-lukas-trnobransky.html
I download “threestars.sparkle”.
The message is displayed:
** The document “threestars.sparkle” could not be opened. **
I do not understand ?
I am under Sparkle 3.0.8
@DesignDealer , Have you tried downloading the template when you first open a new Sparkle document? A popup appears asking your to “chose a template ”, or start with a blank project.
You’ll find ThreeStars amongst it…
Yes, It the same thing !
FYI, it doesn’t work on my two computers at home (under High Sierra). Monday, will I try on a computer with Catalina?
@DesignDealer , Best then to report it to Duncan at feedback@sparkleapp.com
duncan
June 4, 2021, 12:16pm
5
This is most likely to be caused by one of these two issues:
apps like CleanMyMac or Onyx removing localizations from Sparkle
Sparkle being moved while running
We have fixes for both in the next update, for the time being you can re-download Sparkle and it will work.
I’ve re-download Sparkle and it work Fine ! Thanks
