Hello,
is there any way I can prevent Sparkle from automatically saving my document?
Many thanks.
Greetings
Hello,
Many thanks.
Greetings
You can turn off versions globally by checking this checkbox in the macOS System Preferences, general section:
To disable document versions for just Sparkle you need to use the Terminal, and enter this:
defaults write eu.riverdesign.sparkle ApplePersistence -bool no
Many Thanks! Unfortunately, the workarount does not work via the terminal. As soon as I make a change in my web project, it is automatically saved in the Sparkle Projektfile.
Saving takes place immediately after every change, not only when closing sparkle!
Sorry for my bad english.
macOS = Big Sur + Sparkle = Version 3 (German)
The System Preferences checkbox does work. It is likely that you need to close and reopen Sparkle.
Autosave is a system feature, that’s why the setting is in the System Preferences, and yes it saves some time after a change, or when switching to a different application. Sparkle only responds to the system asking for the file for the currently open project, we don’t control and can’t affect the policies on how it’s done.
Thank you for the great help. That helped me
Nice - cause I was looking for the exact same thing! ![]()
I’m sorry but I don’t really know.
