Drop down menu background color issue
I can’t see to change the colors of my drop down menu so that the text underneath the menu is not visible. In other words my drop down menu shows the text it should be covering up, so the drop down is not readble.
The opacity of the background color is 100% in the color menu, and I don’t see on the menu how to make it so it’s not translucent. I’d like the background color to be white.
If my description doesn’t make sense you can look here, and try the drop down on the “danish binidings.”
Thanks for any help.
Mark
It seems your issue with the dropdown navigation is only present on your home page. The other pages your dropdown navigation seems to work well with the background not showing through.
Check out your settings for you other pages and make sure it is working as such on your home page. Clicking on the home link, please go to your right hand panel and go right to the bottom and you will see Mouse Hover. Check these out to see if you haven’t got a Background Colour that is transparent.
Also check out your dropdown under your Danish Binding link on mobile. Your Item Height or Line Height is far too big.
Thank you for catching that it was working on the other pages.
The settings on the home page seem exactly the same as on the other pages, except they’re not working the same. Same color selections, and every other selection seems the same on Home page and all the others I looked at.
Another thing with the home page is that you can’t scroll down through all the options in the drop down menu, the drop down menu disappears.
Should I delete it and recreate it?
Thanks so much for your help, I greatly appreciate it.
Mark
It’s hard to know what exactly has happened.
Maybe, if you don’t see it has too much extra work, it is best if you delete it and start again. I say this because you cannot find any difference between your home page navigation and the rest of your pages’ navigation dropdowns… Remember if you delete your navigation widget it will also remove it from all your other devices.
The other way you can go, if you believe it may be a bug., is contact Duncan at feedback@sitely.app sending hip your project file…
Again, thanks for your help.
I think I’ll just remake it. Just feels like something got corrupted (by me!) rather than it being a bug.
I appreciate your help with this.
m
