Made a vertical menu but it stays dropped down at all times.
I made one previously and it drops down on roll-over. Cannot for the life of me figure out why this one won’t. If I switch it to horizontal it just becomes horizontal with all items visible, then weirdly, if I switch it back to vertical, it hides half the menu items.
I tried just copying the existing one, thought I would just edit it, but it won’t let me make changes in the copy.
So - how do I tell a menu to drop down on roll over?
Thanks
It it possible it is opening up behind an element, hiding most of it?
No, definitely not behind anything. The menu is permanently dropped down, over the other page elements. I just need it to do that on roll-over only.
The other existing drop-down menu is right next to it and works fine. I can’t see any difference in the settings but I must be missing something.
Edit - I gave up and went with the previous menu, which I made 2 days ago, and which worked fine, but wasn’t quite what I wanted, but since it actually worked, I went with it. Deleted the non working menu. I’ve made zero changes to the menu since, it was online and working. But now, after I moved objects on a mobile layout page, the previously working menu has stopped working, hasn’t been edited, just stopped working - won’t drop down on roll-over.
Also just noticed, small thing but… text in the menu is changed - I have one link in the menu which is labelled “2025 Programme PDF” - but appears as “Programme PDF 2025” in the menu. I just changed it to '“Programme 2025” and it seems to have updated OK.
Could you please provide a screenshot… Thanks.
Last note - the menu started working normally without any setting changes after 4 or 5 export attempts. Don’t currently have any info as to why.
