How can i fix items on a sparkle side, that they keep their place at the same position during scrolling,
so that they are always visible ?
My problem is that the side bar menue dissapears during scrolling …
XA
XA
Hi @ArminR, you can do that using the stick to top option of groups and layout blocks:
https://sparkleapp.com/docs/groups.html
So select the menu and a background box, group them, then select stick to top.
Have you considered a sticky popup?
Hola
thx for your hints.
this was what I‘m looking for
it works
Xxiao Armin
