Peafor
February 16, 2020, 1:56pm
1
Can anyone tell me if Sparkle creates a folder called “resources” on the server when it uploads?
We used to use Freeway and I think it might be leftover from that but I am loathe to delete it without being sure.
I will back it up before deleting anyway just to be on the safe side but don’t want to delete something that Sparkle needs.
TIA
Pauline
Gjo
February 16, 2020, 2:03pm
2
Yes it’s a leftover. You can safely delete it.
Peafor
February 16, 2020, 3:27pm
3
Thanks Gjo, nice to have it confirmed
habboud
February 18, 2020, 9:58pm
4
FWIW, what I do is rename the folder, e.g. “pix” becomes “pix_OLD_TO_DELETE__”. Then I use a tool to check for broken links and wait for a few weeks, just in case. If nothing breaks, then I delete the folder.
Peafor
February 19, 2020, 7:19am
5
Thanks @habboud that’s a good tip.
