Footer weird behavior
I set footer on my site and made it Show on all pages and Move with page bottom. The problem is that on certain sizes, like PC and Landscape it gets stuck in the middle of the page and cannot be moved. What do I do? Thanks!
So did you in act “Show on all pages and Move with page bottom” @YaWb after you had created all your website pages? If you did then that would explain the issue you are having.
If it is the case it is just a matter of dragging your footer-section to the bottom of the page (on all pages) and after that it will follow the page bottom.
Do you have some hidden / invisible objects near the footer?
