Greek fonts will be used at some point in sparkle;
My language is Greek, at the moment I use the system times “times new roman” I would like to ask what happens if the user does not have the specific font installed?
Kalimera Gianni,
I also use Greek fonts and have done as MiWe suggests. As the fonts I installed (custom web fonts) are no system fonts, I do think that Sparkle connects them somehow - non-technically speaking - to the file, so that everything will be displayed as you designed it. Otherwise the custom web font should be replaced by a system font like Times New Roman.
Thomas
Ευχαριστώ πολύ Θωμά!!
Να σαι καλά και καλό απόγευμα από τα Σφακιά!
Αγιος Νικόλαος εδω κοντά είμαστε!!!
Για κοίτα να δεις ποιους ενώνει αυτό το Σπάρκελ, μακρινούς και κοντινούς. Καλή μας μέρα λοιπόν, Γιάννη!
