Hi there,
I am new here!
Please I am wondering if there is a way to have Hamburger animated, I mean having an animated effect in order to swing the three lines into an X (and back to three lines).
Thanks!
Hi @Nemo, welcome onboard!
It would be a nifty feature but at this time this isn’t the case with the hamburger navigation.
You could try a button triggering a Popup for your mobile navigation instead.
With the Button you can place a background image and then on the hover state change the image to something else. Not exactly in what you asked but very close…
Thanks FlaminFig!
Yes, your advice sounds a good plan B.
By the way I like your site, which has the menu solution I wanted
Here is an example of the solution @FlaminFig was recommending.
