Having Trouble with my HD-Space. So I searched the biggest user and Apple told me this:
what can I do?
what can I do?
I wonder if you go to Sitely / Settings and remove the Published Cache, if that would help?..
this will delete only about 2 GB
Those are document versions, stored by the system somewhere hidden. It’s not Sitely itself, it’s your project file, multiplied by how many backups the system kept of it.
So the location where it’s saved used to be a folder in the root of the system disk, in a folder named something like .Document-Revisions-V100, but this changed in some recent macOS version, so you can’t quite go in and delete that.
What you can potentially do is:
A terrible, not very effective UI, that as far as I know is the only user-facing way to delete old versions of a project.
Found my own way with “CleanMyMac”. With the “Magnifying Glass” I found the hidden 600 GB Data and deletet it… no further problems…
