Hi I have just made a better web site with the latest version.
I am not great at this but wondered if it’s possible for the lettering in a header menu column on the page pressed then arrived on for this to change colour on that page so it indicates which page a visitor is on because the font is a different colour. On my old version of sparkle I didn’t use the menu feature so could do this. But I do want to use menus now.
Unfortunately, this is not possible yet. It’s a feature that many people have requested, so hopefully, it will be available in the next version!
In the meantime, one workaround could be to place something behind or below the menu button corresponding to the current page. However, you would need to set this up manually on each page.
There are a few ways you can go about it like using text or buttons, even if your use Sitely’s Menu widget.
All you need to do is design your navigation on the page the User lands on to indicate the page is active. Or you can add an element to indicate it as I have done here…
So I would have the gold underline on each page, so when the User clicks the navigation for the page they want to see then they will also see the navigation marked to indicate where they are in the website.
