How do I add an ssl certificate to my side...?
My server suddenly turns down a Sparkle made webpage calling the connection “not secure”… Obviously an ssl certificate missing.
I haven’t had this problem before between my server and Sparkle. Did I miss out on something? How do I add an ssl certificate to my side… ?
A bit of a strange one…
Sparkle has Notting to do with SSL. If anything if you have embedded URL’s in your Sparkle document using the “http” instead of the “https” then yes you can have issues.
Your hosting provider is the king over the SSL Certificate.
I don’t think you have given us enough information though regarding your server calling your connection “not secure”. It could even be you internet? Anyways we need more to go by…
As FlaminFig told - your provider takes care of the SSL Cerificate.
You may either call the provider or watch on your providers website - your account to check.
Me personally I prefer to let the provider do the job after some phone call.
Mostly the first SSL is for free - depending on your provider, though.
Kind Regards,
Uwe
