I am a big fan of Sparkle. Only one thing I am missing— BLOGGING.
Anyone have a good idea to create blog with sparkle or any other easy drag and drop software.
Thanks
Ajay Walia
Thanks
Ajay Walia
@waliasdigital, Welcome onboard!
For now the best way to go about it is follow Duncan’s method on the Sparkle website - https://sparkleapp.com/blog/ Of course you can jazzy it up a bit more if you’d like but I think this is the best method at the moment.
You’d have a normal “top level” blog page and then your post pages would go within a “Section”. Have a try and see what you think, and good luck!
