How to Remove Empty Space on Desktop Caused by Mobile-Only Design Blocks in Sitely?
Hello community, this is my first time designing a website, and Sitely has helped me a lot; it’s very intuitive. The website I designed doesn’t have a layout that automatically scales to mobile devices, so I needed to create new design blocks specifically for mobile. To prevent them from showing on the desktop version, I simply deactivated the “show on this device” option, which worked well during the design phase. This allowed me to hide the new blocks and adjust the canvas size to the visible design blocks.
My problem is that on mobile, the canvas size behaves correctly. However, on desktop, even though the content of the blocks isn’t visible, all the space caused by the mobile blocks remains published. Is there a way to fix this? Why doesn’t this happen on the mobile version but only on desktop?
thks!
Would you send the project file? We’ll take a look. swisstransfer.com
Hello Ducan,
recent problems have been successfully resolved.
My final problem could be the same as iker.santana’s…
With my design blocks there is no problem with large devices, however - as with my colleague, when the design is adapted for small devices there is a free space under the block (this cannot be seen on the workspace, but only on the left in the preview). So you can’t go by WYSIWYG.
Did you have a solution for this?
My site: 80salive-band.de
thx
Send the project with swisstransfer.com and we’ll take a look.
I downloaded at swisstransfer - how can I give it to you (link to the transfer?)
thank you
Send the transfer to feedback@sitely.app
I sended the project to you the last night.
thx
