How do I add anchor text to internal outer links? is there an option? Thanks
Are you saying @YaWb that you want to link to an external anchor link outside of Sitely?
No, Screaming Frog and others told me that my site has an issue, such as that it’s internal outer links miss anchor text. Unfortunately I can not seem to find the option to add anchor text to the links. I can add to the text block, but not to the link. Do I miss something?
Yes we need a bit more attention to these areas…
It is a good idea to place a very precise description (the Name of it) on your anchor tag function.
At the moment we can’t add a description text, aka “alt” (the ones the audio readers use) to links, like buttons and inline text links.
I suppose Duncan needs to see this comment and hopefully add this feature in future versions.
I’m not quite sure what “internal outer links” means.
I assume this is about accessibility and it’s an area we are necessarily going to focus on.
