Hello ! Is Sparkle https compatible?
Hello,
yes, Sparkle is „compatible“. You have to book a ssl-certificate at your hoster, than it runs automatically …
Hi @Manu, as @Horst said, Sparkle sites work fine with https and you need to buy the certificare from your web host.
You might need to set up a redirection from http to https, which was covered here.
You will also want to change the address in your general site settings, to ensure search engines send traffic to the https address.
