Is there any way to get text to rearrange when browser is narrowed?
On many websites, when you narrow the browser window by dragging the right edge to the left, the text arranges to fit the narrower space. But in Sparkle the right side of the text just gets cut off. Is there any way to change this behavior and make the text rearrange? Thanks.
Welcome onboard @Gary :slight_smile:
You’ll come to find out that Sparkle is based on the fixed-width responsive paradigm. That means just about all the elements you use to create a website in Sparkle is fixed and doesn’t flow to accomodate the space your website finds itself in while you play around with the browser window width. It is designed that way giving us Designers a very predictable website result.
Sparkle has Devices instead which relates to your desktop, tablet and mobile layouts. If you have created your website on the desktop device you then need to introduce your tablet device and then eventually your mobile device.
You can find out more about it here and how you can go about making your website responsive across devices - Devices | Sparkle Documentation
