Hi everyone,
I’m facing an issue with Sitely while working on different layouts for mobile and tablet devices.
Here’s what I did:
• I created a box with rounded corners set for the top-left and top-right edges specifically for mobile portrait size.
• When switching to the layout for iPad in portrait mode, I adjusted the settings so only the top-left corner remains rounded.
The problem is: when I make this change for the iPad layout, it also applies the same change to the iPhone layout.
Is there a way to prevent this from happening? Can corner radius settings (or similar design adjustments) be saved independently for each device type?
I’d also like to know if there are other settings in Sitely that aren’t device-specific, so I can plan accordingly.
Looking forward to your tips and advice!
Thanks in advance!
Benny
