I am exploring Sitely’s capabilities and was wondering if the platform supports the functionality to retrieve and utilize features based on geolocation data. Specifically, does Sitely allow the integration or use of location-based services to enhance user interaction or customize content?
Hi @l.caspar, welcome onboard!
Now you are pushing it!
Sitely allows you to Embed code into a Sitely page so maybe it is possible. You can also go one step further and purchase the Developer Package allowing you to place PHP into the header of you page(s).
Going beyond all that you will need to start coding…
hi @l.caspar, welcome.
That’s a bit vague, perhaps you can provide more detail on what exactly you are looking for or what you’re trying to achieve.
Sitely has some limited functionality built-in. Namely you can add a photo that contains exif geolocation information, and extract that to show the location as text on the page, or to show the location as a map.
Thank you! What I am trying to achieve is that a specific website or feature on a website opens when a specific location is entered by the device, in almost all cases a smart phone. Does that make sense? I am quite new to building websites, so still have a lot to learn.
Thank you for you tipps; still quite new to building websites, so will try my best
Sorry but not really.
